Hello all,
I have an MCS2000 installed in my 2008 Chevy Impala. I just recently purchased and installed a (used) Motorola HMN1086A handset. The handset came with the cup holder and of course the handset. I have the cup holder drilled through carpet using 3" screws into the sheet metal below for a secure install. However, it seems that my MCS2000 thinks the handset is off the hook even when it is installed in the cradle. Thus, I always have audio coming from the handset only and never the external speaker.
In theory, when the radio is in handset mode (set through a menu option in the radio) and the mic is "on hook" (in the cradle), audio is supposed to the external speaker. When the handset is picked up and "off hook" (out of the cradle), audio is supposed to be routed to the handset only and the external speaker is muted until the handset is replaced. I've done some research and it appears this handset uses a reed switch which determines if it is in the cradle or not (ie; on/off hook).
When I have the radio in handset mode or not, it still thinks the mic is off hook. However, when I do not have the radio in handset mode, audio comes out both the external speaker and the handset.
My handset did not come with the metal "angled" bracket, just the cradle and handset. I'm wondering if that met bracket is what is needed to make the magnetic connection for the reed switch?
Is there anyway I can make this handset work normally? Am I doing something wrong?
Worst case scenario, I can turn handset mode on when I need to hear and communicate on the handset only, but I'd have to turn it back off to listen to normal traffic. I'm trying to bypass this step so I can use it the normal way described above.
Thoughts anyone?
Thanks!
Thoughts anyone?
Thanks!
