Motorola Help
AHuffman
Warren, Pa
I need some help with the programing of my radio, I am using Motorola ht1250s, When I key up portable 1 on the screen of portable 2 I want it to display 561, I need to be able to "ID" multiple portables.
K2NEC
NA
Use an MDC system to assign an PTT ID for pre and set the ID's to whatever you want them.
Then make sure every radio has "Display Decode ID" enabled.
brndnstffrd
CT
You also need to assign a name to each of the ID's being used in the MDC Call list if you want it to show anything other than the 4 character MDC ID that you give each radio.
RKG
Boston, MA
MDC IDs take the form of a 4-digit hexadecimal number, subject to the following rules:
0000h is not valid.
E is not valid in the first digit.
F is not valid in any digit.
