Motorola HT-1000 Rated Audio Seems High
slackcc
Hi all,
I am attempting to perform an alignment on an HT-1000. I'm using an R-2600 and the 4035 test box. The issue that I'm seeing is that if I set the RF generator to the proper freq, 1mV output as stated in the service manual and then monitor the AC audio level the level is coming in at around 1.3V, much lower than the 3.74Vrms specified, but it's already very loud, to the point of distortion so turning up the soft pot doesn't seem like the solution (and I don't think I could get it anywhere near 3.74V anyway).
Does anyone have experience with aligning HT-1000's that might be able to shed light on this?
Thanks,
Chris
slackcc
Hi cmdrwill,
I'm measuring audio by connecting the universal connector to an RTX-4005B box, setting the box to "Audio PA" and the Audio Out as "MT" with either "speaker" or "load" selected (as expected both settings yield identical results) and then connecting the AC/DC Mtr connections to the R-2660 through the "Vert/SINAD/DVM/Counter In" connection and selecting the AC Voltmeter with a 10V Range (or auto range). If I measure the audio from the AC/DC Mtr with a standard AC DVM I see similar results.
I've also tried this on 4 different radios and all yield results in the 1.5V range, nowhere close to the 3.74V range. So I figure I must be doing something wrong.
Any help appreciated.
Thanks,
Chris
