Motorola ht-1250 trouble
ems82494
Good evening,
I have a Motorola ht-1250 that I use with my ambulance agency, on the main dispatch channel when the motorola two tone page is sent out from county communications I will hear the A tone but the B tone will be muted. I won't miss any of the dispatch though because when the B tone is done the radio will unmute. I checked through the programming to check and see if I missed something obvious but I cannot find anything. Anyone else have this problem? Any idea what to check in the CPS?
Thanks! Have a good weekend!
firefive76
Kansas
Good evening,
What frequency is the B tone?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Good evening,
OK, how about telling us what you want it to do and what it is doing? All you have said is what it does. We really need more info before anyone can help you.
ems82494
What I would like is to be able to hear the dispatch tones without the radio muting on the b tone. I do not have the channel set up for motorola quick call signaling. It is just a straight tx/re channel.
R8000
Low Battery
Turn off MDC1200 decode ? Perhaps your paging B tone is close enough to be falsing the MDC decoder.
Thunderknight
Bletchley Park
Maybe the radio PL decoder is falsely turning off during the B tone. Perhaps the tone is over deviated.
What happens if you program the channel for carrier squelch (CSQ) receive?
SteveC0625
You say you "checked the programming." Without know how you have it programmed, it is just not possible to verify that you have it right or to help you fix it.
You really need to provide some more info here.
