It's called an MTVA and it will cook the battery just as sure as hell if you let it. Personal experience here, and especially if you use it as your mobile unit when in the vehicle. The lure is that it makes your portable a mobile unit, especially if it has the RF amp, too, but there are some real drawbacks you should be aware of before making the plunge.
Because the charger portion will protect the battery and not allow it to charge unless the battery temp is in a "safe" range (below ~85 degrees or above ~40 degrees), hot interior temps in summer and cold temps in winter mean the charger will only trickle charge at or near the edges of the safe range, and not at all above or below.
If you use it as a mobile unit and as yer portable, just remember that it will begin the rapid charge routine each time you place it in the charger, and since it uses a temp vs charge level routine, it lets the battery get pretty warm before it backs off to trickle. This repeated heating just kills the batteries and never lets them properly discharge, so when you repeatedly pop the portable outta the MTVA and then place it back there several times per day, it'll never allow the battery to properly cycle. The long and the short of it is that you can expect a pretty smackin' reduction in battery life.
My experience using it this way every day gets me about 6 months out of a battery before it becomes relatively unusable at about 3-4 hrs per charge, and much less if you need to talk a lot. At the price of MotherMoto's units, that would be unacceptable except that mine are provided by the mother organization. The only aftermarket batteries that can hang with the Moto variety in this kind of abuse will cost nearly what the Moto units do when Motos are quantity discounted to a government entity.
I use JT1000 with an MTVA and all I can say is it's great BUT.......there's no substitute for a real mobile unit.
