Motorola Ht1000 Knobs
thecircusbear
Quick question, as I have been unable to find any info on the net. On the Motorola HT1000, what diameter are the shafts for volume and channel control? Any help is much appreciated, thanks!
thecircusbear
main issue is its for another project of mine. They wont be used for an HT1000, i apologize I shouldve included that. But I know the application Ill use them for have the same size shaft as the 1000, but have no way to order any without the proper size
jhooten
Paige, Republic of Texas
They are not round. The knobs have a D shaped hole larger than the size of the control shaft so that a spring steel retainer fits in to grip the shaft. So do you need the shaft size or the hole in the knob size. I'll measure one for you, but I need to know which one.
Shaft diameter:
Volume: 9/64", or 0.14", or 3.50mm
Channel: 1/8", or 0.125", or 3.21mm
This is from an old worn HT1000 I have. It should get you close enough, though. As JHooten says, they do have a flat on them to key the knob to the shaft.
Disclaimer: I'm not a machinist, so my tools have limited accuracy. +/- 0.001 inches or +/- 0.02mm. If you need tighter specs, you'll need to rely on one of these other guys to provide them.
thecircusbear
Those are the shaft diameter? If so, that's perfect. Yes, they are D shaped, I just needed the correct diameter so I can find the size I need for sale. HT knobs won't work but the shaft size is the same as what I'm working on.
