scansomd
I have been told the HT1000 can be field programmed to scan some or all of its 16 programmed channels. Can anyone tell me, step by step, how this is accomplished?
NeFire242 said:There is two buttons at the left side. Upper opens squelch. We will use lower for manual scan list programming. You can only scan 8 channels.
1. Turn on the radio
2. Press lower button and turn switch at a top of radio in to scan mode (continous BEEP tone)
3. Release lower button (BEEP tone will stop),
4. Set channel knob to a channel you want to add to scan list
5. Press a PTT button (single short BEEP)
6. Set another channel to add to scan list with channel knob
7. Press a PTT button (single short BEEP), You can set maximum 8Ch for scaning.
8. When you finish with adding channels just turn switch at a top of radio to middle position (single long BEEP).
atatistcheff said:I found this thread but it doesn't look like there was ever a procedure posted for programming the scan channels on the HT1000. Does anybody have that procedure handy?
Thanks!
Alex
SLWilson said:On the HT1000, there is an A,B, C toggel switch just under the On/OFF/Volume control knob.
When set to A, the radio is IN the scan mode.
When set to B it is NOT in the scan mode.
When switched to C, it is in the scan program mode. There is a green button on the left side above the PTT switch. When you set it to C, you switch the CHANNEL SELECT knob to the desired freq you want to add to the scan list. When there, you push the green button. ONE push gives you a red indicator light on the top of the radio. A 2nd push gives you a GREEN light displayed. A 3rd puch gives you NOTHING lit up.
The 1st push (RED light) means you have selected THIS freq as your PRIORITY channel of your scan list when scanning.
The 2nd push (GREEN light) means it is just IN the list, not as a priority channel.
NO light means it is NOT entered into the scan list.
Once you have your list set up, simply flip the A,B,C switch back up to A and you're scanning what you selected.
HOWEVER All of the above is dependant on whether or not the ORIGINAL setup programming from the factory set the radio up for these features to work. If it WASN'T set up that way, you'll have to have it reprogrammed to activate the buttons and the toggle switch for those features to work....
Let me know if your worked!!!!
Steve/KB8FAR
