Motorola HT1000
Ted240
Southside, Virginia
Hi everyone,
I am looking into buying a Motorola HT1000 for HAM Radio, Civil Air Patrol, and Fire/EMS. My agencies use DPL on some of their frequencies. Do I need to determine the TX and offset of that frequency if I have the DPL? Im sorry if this seems like a dumb question.
Thank you in advance,
KK4PNQ
They should be able to supply you with a sheet of the tx and rx.
Just keep in mind the ht1000 is a analog only radio.
You would want a model that ends with DN.
zz0468
Yes, you need to know the exact TX and RX frequencies required, as well as the TX and RX PL or DPL. It's all programmed in separately.
Will001
Lexington County, SC
I bought a xts5000 mod.1 VHF for 99 dollars. It has 48 channels and has P25 capabilities...I use it for Civil Air Patrol
Project25_MASTR
Millennial Graying OBT Guy
Texas
Also remember the HT1000 is a 20 year old radio and will only cover up to 16 channels. I know CAP has been attempting to standardize on P25 for the last decade but don't know the current status of that.
Will001
Most CAP repeaters are dual mode FM/P25 that I know of
Project25_MASTR
Texas
I've yet to see one with the vocoder to convert digital in to analog out. Leave it to some 3 letter agency to forget to program their radios with an analog option so everyone is on the same mode.
Will001
Well... those do exist... but what we use are Quantar repeaters that have 2 modes on 1 frequency, for instance a mobile station tries to contact the local base station, but has scratchy audio. The base station tells the mobile station to switch to "digital" (P25). They are still on the same frequency, but on a different mode.
Project25_MASTR
Texas
Yea. It's just a option in a Quantar to enable analog access for the channel. There is a vocoder option but it's a separate box that plugs into the V.24 interface IIRC.
mikewazowski
Forums Manager
Oot and Aboot
Most people refer to a Quantar setup for mixed mode operation as dual mode.
The setting is called Modulation Type and CAP's repeaters would be set to Analog/Astro CAI. Analog in/Analog out, P25 in/P25 out.
The box that converts the v.24 stream to analog is a Digital Interface Unit (DIU). These can also contain encryption cartridges which will encrypt/decrypt analog audio to and from the Quantar.
N4KVE
PALM BEACH, FLORIDA
Hi everyone,
KK4PNQ
Spend the extra $10 & get a MTS2000. Same RF board, but many more features. Also programs with CPS, which means Windows laptop instead of DOS.
