Motorola HT1250 volume issue
GBLOCK
The Sunshine State
When the volume is turned up on my HT1250 the audio quality drops drastically. It is always the same point on the volume dial (and on all of the channels). The radio works fine other than this issue.
I use other HT1250s and HT750s at work and have no problems with audio quality dropping. Is there some setting I can change in the CPS that is causing this issue?
spitcher1992
Cairo, Illinois
try turning audio processing filter off.
in cps go to radio configuration-->basic
it will be the second check-able box down on the right hand side..
i had the same issue about a week ago and just happened to figure it out on my own.
