Motorola Lithium Ion Impress Battery Question
Charlie1068
Houston, TX
I just purchased 2 OEM Lithium Ion batteries used off EBay. One of them works fine but the other will charge fully but won’t turn the radio on I also reconditioned the battery once. I tried it on my XTS 3000 and 5000 but still didn’t power on. I read on a manual that if the battery was in storage that it could take more than one reconditioning to get it to come to life
Charlie1068
Houston, TX
That was the risk I planned on taking with them since they are used after all thanks for the help I will try that and see what happens
GTR8000
NY/NJ Database Guy
BEE00
Yeah if you got them cheap enough that it was worth getting one good battery out of the purchase, then you don't have anything to lose by trying to run the other cell through a few cycles.
Charlie1068
Houston, TX
Yea I payed 19.99 per battery so it’s high risk high reward in my opinion thanks for you help again
K2NEC
How long does it take to go from reconditioning to charged? I bought a lot of 6550 batteries for dirt cheap and a handful of them went from steady red to steady green in maybe an hour. Service life was 20% on em but hey dirt cheap is dirt cheap.
But as mentioned above, try a few recondition cycles.
Charlie1068
Houston, TX
It was probably around 35 percent charged it took over an hour to get it out of reconditioning before it started to charge
GTR8000
NY/NJ Database Guy
BEE00
Good point...the recalibration cycle should take at least an hour from start to finish, maybe more depending on the design capacity of the battery and how much potential capacity is left on it. If it's finishing up relatively quickly, then it's probably shot. Surprised that the charger isn't flagging it as end of service life and alternating green/red.
Charlie1068
Houston, TX
It hasnt done that yet I am gonna put it in reconditioning 2 more times and if it doesn’t work I’m gonna cut my loss
Charlie1068
Houston, TX
I put it into a second reconditioning phase over an hour ago at full charge and it’s still in reconditioning mode
chrismol1
P25 TruCking!
Reconditioning it if it not showing then let the impres charger do its thing for a few cycles, use it up on the radio for a few cycles without force and establish a pattern keep using it. They say its bad to force reconditish but since its already a messed up battery. Ive had some new old stock batteries take a few times to fix themselves up to newish condition after sitting for a few years. If you get a Impres data reader you can find out more whats gonig on with it
Charlie1068
Houston, TX
Unfortunately I can’t discharge the battery via the radio since none of the radios will power up at using the battery
K2NEC
Funny you should mention that. It seems to be hit or miss. Out of my OEM Impres XPR batteries and I have a battery at 89% service life and it doesn't flash service life. But I have a 94% one that does. Weird ¯\_(ツ)_/¯
Opfor2
Riverside County, CA
It could be that the batteries internal "clock" is out on sync. You would need a Motorola IMPRES™ Battery Data Reader to reprogram the clock.
Charlie1068
Houston, TX
I plan on cutting my loses since unfortunately I don’t own the impress program I’m hoping the seller might be able to send me a working battery but as stated earlier I payed 20 bucks for it so if it doesn’t work I took the risk of that happening
