Motorola M1225 and zetron model 5 paging encoder
JackRimawi
I have a Motorola M1225 and a Zetron model 5 encoder I was wondering on how to wire it up and to supply power from the radio to the encoder. Any help would be appreciated.
n3obl
Ø
PA
You would tap the correct pins into the 16 pin connector on rear of radio. You get power from the power supply powering the radio not the radio itself.
kf8yk
M1225 <-> Zetron
Pin 13 <-> J2-2 (12 VDC)
Pin 7 <-> J2-3 (Ground)
dispatch235
Central Missouri
We had the M1225 hooked to a Zetron 10A (still have one for backup) and this is the diagram we have written down for hooking this model.
Looking at the 16 pin accessory plug from the front side that plugs into the M1225 the pinout is as follows:
Only top row is used
Pin 2=Transmit (green wire on this model of Zetron)
Pin 3=Transmit Audio (brown wire)
Pin 4=Ground (Shield and black wires together)
Pin 7=Power+ (red wire)
Like I said, this was for the Zetron 10A, but since there was a link to your model posted above double check the wire colors.
JackRimawi
Can I wire these to cable's to the encoder?
