motorola m1225 ?
markandjere
Franklin County, PA
I was given a Motorola Radius M1225. Model #M44DGC90J2AA. Came with mic and mounting bracket and short power/ground leads. I haven't tried to power it up yet to see if it even works yet . I have been searching the web trying to figure out what exactly the radio is in terms of power output ,channels and band etc. The radio was left in an auction vehicle (not law enforcement........if it matters). Just want to see what I have and what can be done with it. Can some one send me in the right direction to find this info? Thanks
W2NJS
Washington DC
Offhand that's a UHF mobile with narrowband capability. It will cover the UHF hamband via the shift key trick. More information at:
M1225/P1225
Also maybe at Repeaterbuilder.com
markandjere
Franklin County, PA
Thanks , thats a start any how . So it looks like the radio could actually have some use to some one . I have zero exp. with these type radios. Maybe I can find a use for it.............
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Yup, UHF, 25-40 watts, 20 channels. Not a bad radio at all. I have several of the VHF ones in my inventory and they're quite reliable.
FWIW, if you don't have a use for it, check Ebay for current selling prices especially if it works.
markandjere
Franklin County, PA
It powered up and the backlight and display work. I found 6 channels programmed using my pro96 search. The freqs are all in the 461.xxx to 468.xxx range and tagged for some places near where the radio was given to me (NW PA). I was told that it came out of an old service vehicle from a drilling company. I searched the FCC database on RR and found some of the freqs belong(ed) to a comm company and some belong(ed) to a drilling outfit ,both in the general region. Now have to clean it up and see what I want to do w/it. I would like to find out how to access the keypad controls but will probably need a manual to learn how to do that.
SteveC0625
The A B C buttons are programmable for different functions. The only way to know for sure what they do is to read the radio. It may be possible to figure some functions from playing with the buttons, but the CPS codeplug will tell the whole story.
