Motorola maratrac not transmitting
timmy2
carson
I got a maratrax low band off of eBay and got it programed then installed it and it only transmits vary little it don't raise the needle on my swr meeter so got another one got it programed it dose the same thing I tried a none good antenna I checked the power and grounds I tried a different control head and wire harness still don't work they were sed to be tested wen I bout them is it possible to bern them up from programing
Im pulling my hair out please help I don't now if they worked wen I got them or not
northzone
Northern California
Besides the small yellow and green power leads do you have a fuse in the LARGE RED lead that powers the transmitter in the radio?
petnrdx
Hudson, FL
Could be a few things.
A Low band Maratrac draws about 26 or more amps on TX.
Are you powering it with something that provides enough current?
What band is the wattmeter made for? ( a CB one won't be accurate )
Last, what was the freq before you programmed it and the new freqs?
You often can't change the freq range more than a few MHZ without re-tuning the VCO's.
And they don't like going "out of band" without some modification and tuning.
They really are great radios once you get the bugs worked out.
Mr_Observer
I forget if its the orange or the green lead but one of those two will inhibit transmit if 12v is not applied.
N467RX
Panama DB Admin
Prescott, AZ
Aren't the Maratracs really fussy with the wiring? something along the lines of two power wires that have to go to the same power supply or else they won't work.
Also, Batlabs says that if it's the low band radio you do need to do some modifications to go to 50-54 (from the original 42-50)
DPapay
Morris County, N.J.
Yes, the green wire is supposed to go to the exact same point as the main red power wire at the battery. The orange wire is the ignition control, provided that JU1003 has been removed in the control head. I'm just assuming you have the control head with the lit up numeric display.
