Motorola maxtrac and radius
FREEKIWI
I have aquired these 2 radios and know nothing about them
Maxtrac 888 D35MWA5GF6AK
Radius GM300 M44GMC29C4AA
Looked on web but cant make sense of info.
Any info will be appreciated
Located canterbury NZ
FREEKIWI
Yes. Old, old DOS software.
I'm still running a few old VHF GM-300's on UTV's. Solid radios, but not much in the feature department.
Analog only, so no much you can do with them, especially the 800MHz model.
thanks. is software still available
petnrdx
Hudson, FL
I could not find the exact model (C instead of the F), my books show that to be a 15 watt trunking version.
Not too useful.
You could change the firmware to conventional, and reinitialize it to be a conventional analog radio.
But not really useful even at that on 800 mhz.
We used to change those to conventional and make them 900 mhz receivers for ham band repeaters, but there is a lot
better stuff around.
So its really only useful for parts.
I've even removed the ceramic filters and programmed them for low side image to use them for 700 mhz receivers.
More work that it is worth now, other stuff has become so much less expensive.
FREEKIWI
Not too useful.
Thanks mate. radios cost me nothing, So I will keep looking for ways to make useful.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
They are ancient, more than old enough to drink. Old enough to retire from most jobs. They're from the 80s and 90s.
I would not recommend putting any effort into them. Odds are they aren't even narrowband capable, and thus would be illegal to operate on most commercial frequencies. But they are solid, reliable workhorses.
tropiradio
There is also a windows (XP?) ported unofficial CPS for the GM radios that also runs under win7, but it only allows the most basic parameters to be set and is not very intuitive as I recall. More ideal to get the DOS RSS version working in an old computer running DOS v6.1.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Dual core machine with a real serial port and FreeDOS or DOS 7.1 from Win 95/98 works just fine. Don't even have to disable the cache.
dryfb
America
Very late reply, but I use a windows millennium edition laptop and the windows DOS box to program my maxtracs. It works most of the time but one maxtrac always gives me issues though it is a 32 channel one.
