Motorola Maxtrac Question
mesoman
Lewisville, Texas
I just got a hold of a Motorola Maxtrac mobile. It powers up and some channels show to be busy at times but I have no audio. Does the 16 pin extension speaker have to be plugged in to receive audio from the radio??
Thanks,
Brian
jhooten
Paige, Republic of Texas
Maybe. I just picked one up that had a speaker mounted in the front panel but the wires from the speaker to the audio board had not been installed. Ran some hook up wire from the speaker to the point on he board where the internal speaker plugs in and now it works fine with out the external speaker.
CCHLLM
Yes, if it's a 16 pin accessory plug. Two terminal pins need to be connected together for the internal speaker to work. For external speaker, one of the two that are connected for the internal speaker and the audio low terminal need to be used. Go to Batlabs.com and look under specific model info for Maxtrac or GM300 and you'll find the info you need.
wavetar
Pins 15 & 16 need to be jumpered together in order for the internal speaker to work. Looking at the back of the radio, the accessory pins are on the right hand side of the radio. The last pin to the right on top is 16, the last pin to the right on the bottom is 15.
. . . . . . . .<----16
. . . . . . . .<----15
Todd
