Motorola MCS-2000 220MHz Version - Was There A Determination On Software RSS/CPS Needed?
Wins411
So long story...short version. I was given a MCS-2000, M01MHL9PW4AN, I can use it as is, I have listed what is in the 28 channels programmed into the radio and it is all stuff local to my QTH, but it is the 220MHz variant I am suspecting is the Indonesian type radio. I have read other forums seen mentions of some sort of Euro or Indonesian type of RSS/CPS for the radio that I cannot find when searching, but I do know it was somehow programmed at one point and time because it has the SK hams call sign still in the radio on power up along with the channels.
So, not asking for freebies, etc per forum rules, but I would like to know knowledge wise, what is the correct software that I need, I have an older computer capable of running the needed items, the RIB, serial cables, USB cables with RIB the works, and possibly the right software but maybe some other factor not working. I have tried the CPS 02.02 and when attempt read, the radio displays CSQ, goes blank with lit screen, and then I get a cannot read radio, and radio resets fine. When I try 02.03 MSC-2000 the radio goes CSQ, then the light goes off blank screen, followed by a FL 01/90 error which I have looked that up as well and seen also in the forums that can be from using the wrong software on it, I assume i need to find the DOS RSS as I have had to do for other type older radios maybe?
The radio still resets with power to proper operation and is not bricked. Just need some actual/factual information to point me in the right direction, otherwise just going to use it as it and roll with it.
Thanks.
K2NEC
NA
What you have is an MOF230, the software is a special windows based LAB version and it's pretty hard to come by
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The software you are looking for is called Wookie. Someone was clearing out a bunch of Indonesian radios a couple of years ago on eBay and he included the software with the purchase of a radio.
Wins411
Ok, well I appreciate that information, I have a Wookie version 2.01 (SKY) and it actually reads the radio, but I get several issues with it. First it reads the entire radio, but tells me it has suspicious errors, Error invalid data retreiving block emergency block (block discarded) checksum error in block; squelch/privacy (corrected) error: unsupported radio type (check 12m number) unknown radio model, and eventually radio cannot be programmed. Its a start. But I am guessing from experience that I need a clean code plug for this radio to fix all the junk that someone has evidently put there ?
I see one major problem is that the version that I have does not recognize that there is a 220MHz radio at all so guess I need to find the right version of Mobius Wookie? Am I on the right path there? I figured when it didn't show and the channels showing are 120.000 MHz that something is really off.
