Motorola MCS2000 program
LGLHOOK
West Valley City, Utah
Does anybody know how to get a talkgroup id from a motrola MCS-2000 radio instead of a text id. I have access to a MCS-2000 radio but I want to view the hex id instead of the text id.
N4DES
Retired 0598 Czar ÆS Ø
South FL
You would have to program the hex or decimal ID in as the Channel Alias.
The only ID the radio is capable of displaying automaticially is the user's decimal ID if the radio is programmed to show it.
LGLHOOK
I am not actually programming it, it is already fully programmed. It is a police radio and It shows Text ID (ie. UHP North) I am wondering if there is a way of seeing the talkgroup ID (ie. 19712) that is "already" programmed into the radio.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The only way to see the hex id would be to read the radio using Motorola RSS.
There is no way to get the radio to display the hex id unless you reprogram the radio and manually edit the channel names.
WayneH
Forums Veteran
Super Moderator
Your master site
If you can run Trunker, or better yet Treport since you can tag specific traffic for a radio id, you can do it somewhat passively (no keying up). As you switch channels the radio will affiliate. Watch for the affiliation and just go through the channels. Make sure to pause on the channels for 3-5 seconds so it will affiliate each time.
-Wayne
