Motorola minitor 1
wx5atx
Hello I have a Motorola minitor 1 pager and a radio on the same frequency how do I key up my radio and set the pager off?
FFPM571
Nashvillle
unless your radio does 2 tone encode with the correct pager frequencies ( the minitor 1 still uses physical tone elements aka "reeds" ) it wont happen
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
The Minitor I is pretty easy to open. The metal top panel just snaps in place. Remove that and the entire pager slides out of the case. The tone reeds are small rectangular blocks that plug into the circuit board. The tone frequencies are marked on the case. The board may be labeled which reed is which tone: A B or C.
You need a two tone encoder capable of sending the same tones to trip the pager's decoder. In the old days, they were add-on's to radios, usually a desk top unit of some kind, and were tone specific from the factory. Tone encoders usually key the radio as part of their function.
Some newer radios have the encoders built in and generally can generate any of the known tone sequences. The system is called Quick Call II or QC-II for short.
Do some googling on Quick Call to learn a lot more about it.
wx5atx
Also I'm just wanting a cheap setup for this can anybody point me in the right direction and list the things I will need?
SteveC0625
How much is one of those and where do I find one?
Look, you need to ask full questions and explain yourself better. I have no clue which item you are asking about.
Do some googling on Quick Call II systems and two tone paging and learn about how they work.
Here's a good place to start: Two-tone Paging
What kind of radio do you have and what channels are you going to operate on?
jim202
New Orleans region
There are a few radios that do have the ability to send tone paging. It might help if you give us a clue as to what you have to work with.
NCFire11
I had an old Icom F30-GS to test our dept's pagers. Worked like a charm.
