motorola minitor 2 sv
KD0NDO
i am modifying the tone out pattern and can not find the JU3C3 jumper spot.
i have the sv version of the motorola minitor 2.
i am using this web sight
Minitor I/II/III/IV
thank you
GTR8000
NY/NJ Database Guy
BEE00
GTR8000
NY/NJ Database Guy
BEE00
Correction to my previous post. BatLabs does indeed list the correct jumpers for the II SV models on that page. I don't know how you could miss it, it's plain as day between 1/4 and 1/2 way down the page, along with a link to a diagram of the jumper locations on the circuit board.
KD0NDO
thank you is there any other way than cutting the traces on the circuit board for 3C8 and 3C11?
sorry about that i do want set 8
do i use both of these chunks or just one?
3C1 - OUT
3C2 - OUT
3C4 - IN
3C5 - OUT
3C8 - OUT
3C9 - IN
3C10 - IN
3C11 - OUT
thank you
GTR8000
NY/NJ Database Guy
BEE00
For Set 8, the traces for 3C8 and 3C11 must be cut, per my post in the other thread.
KD0NDO
3C1 - OUT
3C2 - OUT
3C4 - IN
3C5 - OUT
3C8 - OUT
3C9 - IN
3C10 - IN
3C11 - OUT
KD0NDO
i can monitor in the second and third position, there is defiantly a 3rd position, and no vibrate when i opened the case i looked.
can i still change the tone out pattern?
is there any other numbers you want me to give you?
i can get pictures of anything on the pager you want.
KD0NDO
Should i cut 3C8 at A, or B
Should i cut 3C11 A, B, or C
GTR8000
NY/NJ Database Guy
BEE00
None of the above.
The traces are the very thin lines of solder. Before you cut anything, you should try removing them with a soldering iron and some solder wick, they should come right up.
Red - 3C8
Blue - 3C9
Green - 3C10
Yellow - 3C11
KD0NDO
thank you. is there any way to so set up the pager so that on position 3 the pager will not alert?
good thing i can solder well.
GTR8000
NY/NJ Database Guy
BEE00
Close 3A4 to disable Position 3 alerting.
3A4 is not labeled on the board because the Director II SV was never supposed to have a Position 3. See attached photo for the location.
KD0NDO
thank you so much. what kind of camera setup do you have there?
