motorola minitor 2
KD0NDO
can i use a 346.7hz tone reed for a tone that is 349.0hz?
GTR8000
NY/NJ Database Guy
BEE00
That should work fine assuming the console is transmitting a good, clean 349.0 Hz tone and the pager has good reception of the signal. Usually a +/- of 1% is within tolerance, although the tolerance decreases as the tone frequency decreases. The only way you'll know for certain if it works reliably with your pager on your radio system is to try it.
KD0NDO
thank you. and what are the SV settings of these pagers. how long, how many, and how do i reset the SV. thank you for your help.
GTR8000
NY/NJ Database Guy
BEE00
There are three stored voice modules for the Minitor II SV. You'll have to check to see which you have.
NRN7620A - 1 message, 32 seconds long
NRN7621A - 2 messages, 16 seconds long each
NRN7622A - 4 messages, 8 seconds long each
GTR8000
NY/NJ Database Guy
BEE00
Not necessarily, no. It should store the message any time the pager alerts. Generally speaking, it should alert on the Bell and 1 positions at the very least.
pafd152
plymouth
alright, and also... I took the tone filters out of my nonsv pager and put them in this one.. Will it work properly?
GTR8000
NY/NJ Database Guy
BEE00
Yup, the tone filters are the same for all the II series pagers. Just make sure you put them back in the proper order. With the pager laying flat on the speaker, with the control knobs facing to your right, from top to bottom it's A, B and C (C being the one closest to the speaker).
pafd152
plymouth
i have one more question, in the sv one i put them in it only had 2 tone filters in it. I am putting 3 in this one and read something about jumpers. could you tell me in a nutshell about that or if i need to do anything?
GTR8000
NY/NJ Database Guy
BEE00
It totally depends on how your dept is paged out. I'd need more info on the tones to figure that out. Is it two sets of tones with a common first tone (A-B, A-C)? Is it a two tone set with a long tone that's not common to the other tones (A-B, Long C)? Is it a two tone set with a long tone that's common to the second tone (A-B, Long B)?
pafd152
plymouth
And by that you mean? Sorry i'm new with all of this. I put the filters in tonight and it didn't tone out and store like it should. Any suggestions?
GTR8000
NY/NJ Database Guy
BEE00
You can expect up to 2% tone tolerance on Minitor I/II, 5% on synthesized 3,4,5.
FYI the original thread question you're replying to is a year old. :wink:
Disregard Jtsou's post, it was not directed at you.
I think you would be better off getting help locally from one of the brothers who is familiar with the Minitor II, they can make sure you have the correct tone filters in the correct spots and that the pager is setup properly. There are a lot of threads about the jumpers on these pagers, do a search in this section for "minitor jumper". You can also search BatBoard for info.
Batboard • Login
