Motorola Minitor 4 Issues
NCFire11
Didn't work. How hard are these to take apart and see the inside?
Not hard at all- its an allen screw at the bottom, remove that and pull from both ends of the pager, it slides out. But be careful not to break the speaker wire.
BigLebowski
Piedmont NC
There was an issue with Minitor IV's that had to do with the case flexing near the belt clip, causing the components on the circuit boards inside to lift away from their proper locations. Caused all sorts of issues..
mojo3120
That's the tone decoder. Causes "no alert" issues, but I've never seen it cause "no power" issues.
squirrel911
Estill Springs/Decherd/Winchester/Franklin County
Try cleaning the contact on the bottom of the battery cover
Nothing there to clean off. it is nioce and clean. Batteries never leaked. I am very careful about that.
How is that fixed?
That is just it. NO POWER. It worked and then just stopped. IDK what to do.
krokus
Southeastern Michigan
There are lots of possibilities. If you don't have the technical knowledge to know where to look, and don't have someone near you that does, then send it to be repaired.
The link given for UCC is a good, I have sent many Minitors to them, and have been happy with their work.
