Motorola Minitor 6 programing software
joehfd
Hello is anyone aware of the Motorola Minitor 6 programing software issue that it is not compatible with Windows 10? If so, is there a fix or something
Thanks for any help
Joe
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Thanks for any help
Joe
I've had no problem whatsoever running the Minitor VI PPS under Win 10. There is no compatibility issue. It's usually a bad install or corrupt zip file.
You do have unzip and install it. You can't run it as received.
Delete what you've got and/or uninstall it. Get a fresh copy of the PPS from a different, but reliable source. Unzip it into it's own directory and run the install or setup executable. Wiscomm is a good place to get the PPS.
After installation, if you still are getting errors, you can look at the properties of the executable and try changing them to "Run as administrator" which usually fixes issues.
Maybe a better description of what you've done and what error messages you're getting would be just a tad helpful. Your question as worded gives us no place to start helping you.
joehfd
Thanks for the replys everyone, I only asked because Motorola said it was only compatable with xp-win 8
