I am in the process of changing out the 2 crystals in a Minitor II SV VHF-High pager. From what I have researched and seen, the PC board traces on the top side of the RF board are very delicate and can be easily damaged during a crystal pull especially if you use excessive heat or force to remove the crystal.
I have received some advice from a person very experienced in Minitor II crystal pulls. The way he does it is to initially add some new solder to the crystal connection points on the underside of the board. He then heats up one connection point at a time while gently pulling on that side of the crystal with his thumb and forefinger. He repeats this heating and pulling procedure on each leg of the crystal (essentially "rocking" the crystal from the board little by little) until the crystal is totally free from the board. He then uses a solder vacuum to clean up the holes in order to put in the new crystal(s).
Is there anyone here who has done this Minitor II crystal removal and replacement previously and who can offer any additional personal pearls of wisdom, comments or suggestions? I'd rather learn from the "experts" on this Motorola board first before my making any rookie mistakes.
The reason I am attempting this on an old Minitor II is so that I can monitor (in CSQ) my local fire department's VHF-High channels 1 and 2 in a very small form factor receiver. I was lucky enough to obtain the 2 necessary crystals and also picked up some brand-new Minitor II NiMH rechargeable batteries from Power Products. I don't need any Permacode active filter paging components as my local fire department does not do any type of two-tone alerting on either frequency.
