Motorola Minitor III - Static Issues
jz85
When plugged into the base, I am getting a lot of static on my Minitor III. In fact, if it is on, there is static.
How can I get rid of this?
DPapay
Morris County, N.J.
Does the pager seem to rx your dispatch o.k.? By static, I am guessing you mean unsquelch. That is the "shhhhhhhhh" noise you get when you press the reset button. If the pager still seems to rx dispatch o.k., then you could have the pager reprogrammed to "tighten" the squelch in the software. If the pager does not rx dispatch anymore, then it has a problem. Motorola no longer supports the 3.
