Hi,
I purchased a Motorola Minitor IV UHF pager. The pager has 2 channels and stored voice. I programmed the pager with the correct Motorola Software and the programming is correct. The pager powers up with the standard beeps that it makes. I tested the tones and had no activation. I set the pager to a monitor mode and tried testing the pager with my portable radio. I had no luck with receiving transmissions from either transmitting or setting off pager tones. Is there something that can be done to fix this, or is this an internal component problem. I adjusted the squelch levels, and also tried different frequencies. What can be done. and suggestions or help is greatly appreciated.
Thank you,
Cody
Thank you,
Cody
