Motorola Minitor V
Brandon28
Can someone tell me what these diff. modes me on the attachment
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
When you installed the PPS on your computer, the programming manual was automatically placed in the folder with the other program files. I suggest you read over that manual as it will answer your questions and a lot more.
C:\ --> Program Files --> Motorola --> Minitor V PPS --> Manual
MFDHoward
Monitor F1/F2 - Listen to that frequency transmissions all the time while selected on that knob
Selective call f1/f2 - Silently Scans for tones then activates the pager letting you listen to the call
Probability Scan - Scans both F1 AND F2 on a Open/Monitor style mode hearing everything and alerting to a call when the tones come across.
Silent Scan - Scan both F1 AND F2 for tones and listens to call of which tones /frequency were transmitted for
Priority F1 - Makes F1 Priority in a scan of F1 AND F2 and will scan that channel longer in a two channel scan.
Brandon28
Thank you MFDHoward.
There wasn't information in the manual regarding this information, otherwise I wouldn't ask.
SteveC0625
Had you stated that you had already read the manual in your initial post, you would have gotten a similar response from me. But you didn't so I referred you to the manual as a starting point.
We are not mind readers here. We can only respond to the info presented. Tell the whole story when asking a question, you get a much better answer.
