Motorola MTP300 Tetra
mid cities, Texas
I made an offer to someone on eBay of $40 which was accepted for a Motorola MTP300 Tetra radio.
I am wondering what anyone knows about this radio and how I can get it programmed and get the battery, antenna and charger for it?
Raccon
You do need a special software and programming box from Motorola, though I am not sure what you want to program as the radio won't be able to register to any TETRA system since it needs to be authorized in the infrastructure, too. Else it will be not be of much use except in DMO, if you have two radios that is and notwithstanding any licenses you may need to transmit on those specific frequencies.
Anyway, you may take a look here: http://www.cbradio.cz/doc/_HAM/Motorola/MTP200/cps.pdf
Manchester, NH
DMO mode repeater?
First, sorry for restarting a thread... But this seemed somewhat on-topic, and rather than start a new thread...
This may sound like a stupid question, but is the MTP300 capable of using a DMO mode repeater? I'm pretty sure the repeater function itself isn't available, but can it communicate through one? Info on this seems to be spotty, at best, and I can't seem to find a manual anywhere for this model.
Raccon
According to this data sheet it supports 'Normal Direct Mode Operation (DMO)', so I assume it doesn't work with DMO repeaters or DMO gateways.
