Motorola MTS 2000 Problem
FDRadioguy777
I have a UHF MTS 2000 and when I listen to the audio it seems to cut in and out. Any ideas what might be causing this? Do I need to used the tuner to correct something? When I test it short range on the GMRS channels it seems to work just fine.
Also, is there anyway for me to add a talk permit tone to the radio for conventional operations?
MaxK98
The in and out cutting could be comming from priority scan. As for the permit tone, you could add one using MDC1200 side tone.
Will001
Pine Ridge, SC
Check your squelch...my Xts5000 did that, and it turned out the squelch was WAY up (about 8)
