Motorola MTX 1550 Programming
PMan976
Dawson Creek , BC
I have been banging my head against the wall over this one . :)
I am not familiar with the MTX1550 software and I was hoping someone could help .
I am trying to put 44 in one zone and 6 channels in the second zone.
I have all the channels in 2 separate zones so far..
With previous radios I was able to make the 16 position channel selectora zone selector and then i made the front panel or side buttons the channel selector so that i could select over the 16 channel mark.
So far I am unable to find a way to make the front panel buttons be channel " up /down " buttons.
unless there is another way to do it, am I going to have to make multiple zones with 16 channels in each?
I should also mention that I am using the radio in conventional mode only ( no trunking )
I can send codeplug if that helps.
Thank you for any help
TampaTyron
Tampa, FL
You got a maple syrup radio, most of us in the states do not have much experience with the blue CSA units. The firmware for the Canadian radios are often just slightly different than the stuff I have experence with. I am assuming that the MTX1550 uses the HT/CDM software...... what is your firmware version? TT
It is one of many ht1250 flavors. I never recalled the ht1250 or a couple others offering channel selection from front panel unless the rotary was set to zone. If I recall right since it offers it. I never had a need for front channel buttons so I am not sure it was possible least on the ht1250 flavor. I do recall the above being offered to set rotary to zone so I assumed one could assign channels to front after a select button but I could be wrong and you know what they say about assuming.
PMan976
Dawson Creek , BC
It is not one of the Blue CSA Models , But I am sure it is very similar, just not Intrisically safe like the Blue Models
It uses the : Motorola Trunking Radio Professional Radio CPS Kit # HVN9067 Ver: R02.03.00
PMan976
Dawson Creek , BC
I tried setting the Rotary to Zone and still can't find anywhere to set the buttons to channel select.
If that doesn't change anything then it probably does not have channel up or down functions for the side buttons and front buttons. Like I said I never had use for it anywhere else. So you will probably be stuck using 1 to 16 rotary per zone. I had thought this was only case for the 1250s, but noticed the zone rotary option once so figure maybe it was for that or maybe the cdm. Looks like you'll have to configure 16 channels per zone using the channel selector rotary.
