Putting together a new news vehicle, and I need to decide between keeping our existing Larsen NMO150/450/758 with Stridesberg 8 port active multicupler, or "upgrading" to a Motorola EQ000103A01 VHF/UHF/700/800 antenna multicoupler, with three band specific antennas, running into the same multicoupler. I am wondering if the loss associated with multiplexing would be similar to the loss associated with a tri-band antenna. I am not sure if anyone here has any experience with the Motorola EQ000103A01. I have one I picked up for $70 used, and put some BNC adapters on it (has QAM connectors) for testing, but I know all these adapters are also causing some losses, so not sure I can reliably determine through signal testing what the actual signal degredation may be.
If we go multiplexer, would be running a 380MHz 1/2 wave UHF, a 155MHz 1/4 wave VHF, and 5/8 wave 3db 7/800 antenna array. The Larsen tri-band has extremely good 7/800 performance, loosing only a couple of RSSI points to a dedicated 5/8 wave 7/800 antenna. On Military 380 MHz UHF, the tri-band sucks, and on VHF it is not exactly amazing either.
Paul
Paul
