Motorola Online Help
dixie729
Daviess Co., KY
I'm on my Motorola account and have searched and searched for cps R.05.18 for the CM300.
I have R.05.17 and I get the Error#768. I am using the adapter with a cdm programming cable.
Can I get some help on locating R.05.18?
Sent from my XT1058 using Tapatalk
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Resource Center --> Software --> Two-Way --> CP-PR Portables & CM-PM Mobiles
If you can't see it and your subscription is still current, call the Customer Service number and open a case.
Secondly, your problem is not the CPS revision. If you would kindly search here on Commercial Series you will find a number of threads all discussing the fact that the CDM programming cables will not work on the Commercial mobiles without an adapter, either home brew or purchased from Motorola.
http://forums.radioreference.com/motorola-forum/93266-cm-300-programming.html
http://forums.radioreference.com/motorola-forum/208197-cm300.html
There are also numerous threads on the batboard on this topic. The answer is still the same.
dixie729
Daviess Co., KY
All I see are firmware updates
R04.01.02D/ Codeplug R09.01
CM200 / CM300 / PM400
dixie729
Daviess Co., KY
This is all i get
I have just re-did my license and it still says this. I'm I missing something?
This happens on all of the software tabs.
