Hi,
I have been doing P25 monitoring and analysis in a number of places in the past few months, as part of a hobby. One thing I've discovered is that every Motorola system I've encountered so far is sending X2-TDMA identifiers (band plan descriptors) even if the system is configured for FDMA - in that case, it's sending them with "1 slot 12.5kHz" configuration.
Should these systems be submitted to be reconfigured as X2 systems in the DB, or should the DB only show X2 for systems which are actually using TDMA functionality/multiple slots per frequency?
On one hand, the systems are definitely putting out data which a non-X2-compatible scanner will not understand (and conversely that an X2-compatible scanner will be able to take advantage of, one would presume).
On the other hand, as has been seen previously, marking them X2 might put them "out of reach" of some scanners as some software packages consider those systems incompatible with regular scanners, and will not download them.
Looking for the lead admin to provide some input on this and I'll proceed from there. Thanks.
