Motorola PM400 Programming Problem
wv8mat
Letart, WV
Hey everyone, just got a quick question, I just my new PM400 today, sat down with the software, and my ribless cable, and tried to program it, guess what Error 512, connect rib, power on radio, check connection. i have the correct ver of the software, the cable is a all in one that i got from ebay that does mobiles and portables. now i know some of you are already going what the crap was he thinking but it works on all my portable and my cdm and maxtracs. what do i do know.
oh and when the mic is in the radio, it keys the test channel just fine.
thanks
matt
K4APR
Chesapeake, VA.
thanks
matt
Is the radio BRAND NEW from Moto? If so, are you SURE you have the latest CPS? Many times, we would get a batch of brand new radios in and could'nt read or write to them because they had a new codeplug version for default and a new version of CPS was required, but we were un-aware. Usually upgrading to the latest fixed the problem.
I can't say that is the fix for sure, but sure sounds like what we ran into many times. Left hand not knowing what the right is doing.
wv8mat
Letart, WV
no i got it from a guy here on RR so i will send him a message and find out what he had to use on it, i know when you turn it on, it has test only and b-chan and c-chan and thats it,
thanks
wv8mat
Letart, WV
what is the difference, i saw the diagram from batlab and it shows "boot" wire is a difference, is that all ?
thanks
KX5MOT
Lincoln County, OK
The CM200/CM300/PM400 uses a slightly different cable than the CDM/Maxtrac. Pins 6 & 8 need to be shorted on the RJ45 for the radio to be in programming mode for the PM.
wv8mat
Letart, WV
well i went ahead and ordered a new cable hopefully in a few days i can let everyone know if that was it or not, thanks
wv8mat
Letart, WV
ok so i got my new cable and when i goto read the codeplug the message i get is something about the verison not supported. so i am to assume that means i need a new ver of the software, so my question is can i write a older firmware to the radio to get my software to work.
Luis_R
Don't think so.
wv8mat
Letart, WV
well thats no good, how does buying software work with moto, i mean its not like i click buy it now and pay and download. or is it. i cant seem to understand that moto website.
ramal121
Lots and lots of watts
Calif Whine Country
When you buy CPS, you would normally get a "subscription". You could then download updated software for as long as the subscription is valid.
wv8mat
Letart, WV
is that online instant thing or do i have to wait and talk to someone and and get stuff thru the mail?
BATTALION33
OCEAN GATE,NJ
Motorola pm400 programming
hi im new to this site i had a question i just bought a uhf pm400 from ebay and found out a had a problem?
first of all im trying to use a rib box? im guessing im not supposed to do it that way ? and im using a rib cable for a CDM (rib box style?) can anyone help me out ? what is the correct procedure ?
KX5MOT
Lincoln County, OK
Well you didn't state what the exact problem was but as stated above the PM400 uses a different programming cable than the CDM series. While it does require a RIB, the CM/PM series uses it's own different RIB-to-radio cable.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Please, don't you think if you have a problem that you ought to tell us what the problem might be?
Second, as the poster above stated, the CDM cable won't work. You need the cable designed for the the CM/PM series. There are several newer threads on this issue that clearly and fully discuss it.
Third, you need the right software. The Pro Series for the CDM's won't work. You need the Commercial Series CPS.
Fourth, you need the same revision level or higher of the CPS that the radio is currently programmed with. Using an older, lower revision will not work.
firefive76
Kansas
In reference to the "Third," Pro CPS is the correct CPS for the CDM series. Commercial CPS does the CM/PM.
