Motorola portable antennas
Peoria, IL
Hello I wanted to know if you can use a bnc connecter to put on an antenna that is used for the XTS5000. Since the antenna is an sma antenna I am asking if you can convert it to a bnc for a scanner or not. I dont want to waste money on an Motorola antenna and a connecter. Could someone help explain it to me if you could.
Thank you
Forts
Ontario, Canada
I do this all the time. Bought a couple cheap BNC/SMA adaptors from eBay and use various Motorola antennas on the scanner if I'm listening to something band specific.
Peoria, IL
Thank you so much for your help. Now I might go out and buy an Motorola antenna. I just dont know how much the Motorola portable antennas cost. Also does it matter if the SMA is a female or male on it. Would the PMAE4016 work with that adapter.
Forts
Ontario, Canada
Actually... before we go any further... what model scanner are you planning on using? The link to that adaptor from Tessco will NOT work. It has a BNC-F connector (same as what's already on most scanners). You would need a BNC-M connector unless you are connecting to a scanner with an SMA connector (obviously).
Forts
Ontario, Canada
Ok... then you definitely want an adaptor with a BNC-M connector on it. The scanners connector is a BNC-F.
Forts
Ontario, Canada
Sorry bud... I took a quick look but didn't see one. I don't really have time to spend searching around for it... I'll have to leave that part up to you. Or just use the eBay link I already posted.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Depends on what radio. You mentioned an xts5000 earlier which does use an sma antenna.
mancow
N.E. Kansas
The one in the link you posted is a crimp on connector for a cable. Are you wanting to put a motorola portable antenna right on the scanner?
You mentioned a portable antenna earlier so the one Forts posted is the correct adapter.
DisasterGuy
Maryland Shore
What exactly are you looking to achieve here? Why not just use the proper antenna for the application? You will find yourself spending a lot of money for an antenna and adapter considering what you could be a decent antenna with BNC for. There are many good options from Laird, Larsen and others. I run Motorola and Harris radios in public safety and purchase all antennas from Tessco rather than Motorola or Harris given the relative mark-up.
Peoria, IL
Just to use a Motorola antenna on my radio. Do you have any experence with the UHF Terra Wave antenna. Is it a 1/4 wave or 1/2 wave? Tessco says 1/4 wave and 1/2 wave.
