Motorola PR1500 - Can't disable talk around
fonestar
Whitehorse, Yukon
Hi there... programming a PR1500 using CPS.
I can't seem to de-select TA from memory channel 16. Why is that?
Right now I've set 16 as a simplex channel as a temporary work-around but that's not the way it should be. I have other radios and I want all of the memory banks set up the exact same way.
Channel 16 should be a repeater frequency with no TA enabled. I have a total of 16 channels programmed in this radio, no priority scanning, no trunking. No other channels are programmed with TA.
Project25_MASTR
TX-COMU
Texas
It won’t let you disable because it is a simplex frequency already.
fonestar
Whitehorse, Yukon
Hi MCore...
Sorry, maybe I wasn't clear... but channel 16 wouldn't let me disable TA on a Duplex 2M repeater.
So I wound up making channel 16 a simplex frequency which is not what I wanted.
Project25_MASTR
TX-COMU
Texas
Try deleting the personality and re-creating and see if it’ll let you then.
