Motorola PR400 Scan Lists
Chevyman22360
Have a PR400 32 channel with display Radio and software to program. You can program up to 16 scan lists. I cannot figure out how to toggle between scan lists. Manual shows how to edit, add or delete within a scan list but doesn't show how to toggle to each individual list. Thanks
K2NEC
NA
You cant change scan lists from the front of the radio. The scan list is selected in the software in the channel personality. If you want to change the scan list assigned to the channel, you need to reprogram the radio.
K2NEC
NA
You can change the contents of the scan list but not the scan list itself.
Most people dont need to (or want to) change the scan list on the fly.
tyler3328
These radios were designed for commercial uses. Some PS agencies use them in the analog days. They were not designed for everyone to be able to change things on the fly. They were designed to be programmed by a tech and then end users use them as they were programmed. There are very very few to no reason for the end user to need to change lists like a ham
ElevatorsAndRadios
yarewesog
SoCal
Assign scan lists to personalities intuitively so that you know what you are scanning based on the channel you start scanning from. For example, if I start scanning from one of my favorite channels, I scan a list of other channels that I use very frequently and never want to miss a call on. Or, if I start scanning from a channel that's a repeater in the San Gabriel Valley region, then I know I am scanning other repeaters in the SGV, and so on. Get the most out of your radio by thoroughly planning your codeplug and crafting it around how you intend to use it.
merlin
DN32su
Maybe I am wrong here but can't you toggle 'add/delete' to a scan list ??
I need to read up the user manual as I am getting a pair of these soon.
Chevyman22360
Yes you can go in to menu on the radio and add and delete channels from the scan list.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
You can “nuisance” delete a scanned channel if there is a button programmed to do so.
Alternatively, you can add/delete channels from a scan list if set to do so in CPS and there’s a button programmed to access menu items.
nhfdcadet
GCT-1
New Hartford, Ct
1627392661608.pngUnder each personality, make a selection for which scan list you want that personality tied to. When the radio is turned to that channel, it will scan that list.
1627392750322.pngThis is under "Programmable Menu" that needs to be checked in order to change your scan list.
1627392799779.pngYou also can configure nuissance delete under "Buttons" typically I set nuissance delete to be a long press of whichever button turns scan on and off.
merlin
DN32su
OK I just unearthed the manual and in the menu functions you can do near anything with scan lists.
Buttons can even be programmed to manipulate scan lists. Too many things to list here,
I suggest getting your hands on the user manual.
6881096C26-C PR400 Limited-Keypad Model User Guide
6881096C23-C PR400 Full-Keypad Model User Guide
(this is quite a bit more radio than I first thought.)
