Motorola Quantar Programming Cable
caerickson
Phoenix, Arizona
I have been using a USB to Serial cable to program my Motorola Quantar repeaters. For some reason my computer won't recognize the driver for the programming cable. I originally purchased the cable on Ebay and it has worked great, but I have not been able to find a similar cable for sale. Does anyone have a suggestion of where I can buy a new cable.
talviar
Uniontown, PA
Personally I use the Cables2go USB to Serial adapter cable. Cable works flawlessly with everything serial I have to deal with and that includes reprogramming Quantar repeaters
Texas
I've always had good luck with the IOGear GUC232A with everything except for Pro series CPS on Windows 7 64 bit and Windows 10 64 bit.
The cable for the Quantar is simply a NULL-MODEM cable and only requires TXD, RXD and Ground. Over the last few years I just used RJ45 to DB-9 adapters and manually pinned them out to give me a straight passthrough on the computer side and then pinned others out for Male NULL, Female NULL (because the Quantar uses a female DB-9 for the programming interface and the GTR8000 uses a male DB9). Then just hook a standard ethernet cable between and GTG. Also build one for the MTR2000.
Here lately I just have male and female ends and simply use a USB to Rollover cable (if you've worked with networking equipment you know what I'm talking about).
