Motorola Radio Identification
Colton25
Everyone please forgive me for my dumb question, I'm not familiar with Motorola radios at all. I'm just curious to know what radio this is, what software is needed, and what programming cable is needed. I've attempted to do some research on it but I just keep coming up with newer radios. Here's some pictures of the radio.
Redneck0410
Hutchinson, KS
Judging by your second photo, you have an XTL5000. The other pic however doesn't match any XTL5000's I've ever seen.
grem467
Houston, TX
The first picture is a W4 head and is perfectly compatible with the xtl. That said you will probably want the programming cable for the rear accessory port (made in both usb and serial) and astro25 mobile cps. The tag indicates its a VHF radio.
Looking at the flashcode, it's an analog only radio. Unless of course it's been upgraded along the way.
Redneck0410
Hutchinson, KS
Googled it, and you, sir, have an astro spectra plus xtl5000. Note this particular radio isn't manufactured anymore but you might be able to find parts for it still.
KevinC
The big K
Super Moderator
I'm everywhere Focker!
I'm pretty sure an "astro spectra plus xtl5000" doesn't exist...but I could be wrong...:wink:
The flashcode or feature set your radio is capable of is analog only conventional operation. You can have the radio flashed to do p25 digital, adp, trunking etc. It costs but you can upgrade it. The head in first pic is a basic head. Some xtl radios have them most have the newer heads. So it's a good radio. Dash mount 45 watt. To change heads you'd need to find the newer 0 series head and update radio to accept the head, sync etc. Not a bad thing. I know of people who can do legit firmware updates over the net from there pc to yours. It's a solid method without sending it away. As for flash code options they can be costly depending on what you options you want and upgrades such as digital p25. You have a few options so it is a good radio. It is indeed a xtl5000 dash mount.
mancow
N.E. Kansas
What part are you confused about?
"Still not an XTL"
"What you have is an XTL"
Wait, you are comparing the two not just talking about OPs radio I guess. OK I think I'm following now. I need some sleep.
kd8eee
"Still not an XTL"
Sorry, I guess I could have done that better. OP has an XTL5000 with a W4 control head. The link that was posted is an older Astro Spectra radio, not an XTL5000.
Colton25
Ok so I'm pretty sure I already have the software, not looking to upgrade anything an I am aware that it is analog. Can someone point me in the right direction as far as what programming cable I need? I'd prefer usb if possible.
KevinC
The big K
Super Moderator
kd8eee
I'm familiar with all the connectors except for the red wire and the other small connector to the right of the usb, can you tell I'm a Kenwood person haha
Red wire is ignition sense (+12v), and the small white connector is your speaker output.
Colton25
But for programming I would only need the usb and the big square connector correct?
