Motorola Radius M1225 Power Problem
Blandon, PA
Has anyone ever had power problems with these radios? I replaced the inline fuse and traced the wired all the way into the cab nothing is shorting out and i have power all the way up to the radio. When you unplug the power wire from the radio and back in you get a pop noise and nothing after that.
Zack08
Did this radio work in this vehicle before? Does this radio have an ignition sense wire?
Blandon, PA
Yeah, it working great for awhile. The other day it just decided not to turn on. When you unplug the power wire and plug it back in you get like a click sound and thats it. The fuse is inside the radio then? Any idea how many amps it is?
KX5MOT
Lincoln County, OK
There is a little pico fuse inside the radio, looks like a green resistor, take the top cover off and its near the back near the accessory connector
