Motorola RDX business 2-ways
cartman
Conover, nc
I have encountered a technical glitch with an Icom and one of the newer Motorola RDX radio's. It seems these radio's use the Murz channels just as my icom does, only problem is there seems to be a PL or DPL sub-audible tone code I've been told in these Motorola's that prevents the Motorola user from hearing my icom, even though we're on the same frequency. Does anybody here on the forum have any idea where i can find such info because i suspect these PL or DPL codes could be any combination of numbers. My Icoms manual lists 100 different sub audible tone codes so it's anybodys guess what it could be. Anyhow, any and all suggestions welcome.
C138NC
Tactical Taco Consumer
NC Taco Command
Ive read somewhere online that not all radio's will have the same PL's programmed in the same way, you can have your RDX on 192.8 "PL number 31" and your icom on the same thing and get no TX/RX and maybe an LED indicator that you have traffic on that frequency.
Its something i read up on the Wiki and cant really find that particular page of information but it does work when they are both CSQ obviously.. right?
If i could find it, it has a better way of explaining it then what I remember from reading up about it last year.
clanusb
Northern CA
Different companies have a somewhat different set up for PLs and DPLs.
Its dumb and it all should be universal but its not.
I would say your best bet is to grab a scanner with PL/DPL search and enable it. Then tune it to the freq you are using, and key up each radio and cycle through the PL and DPL tones. I would make a list for each radio only for the tones that I use the most, if i had extra time I would make a complete list for both radios that way I could always look them up on my chart.
Its a pain, I know, but what are you gonna do?
cartman
Conover, nc
I appreciate the help, and thats exactly what I've noticed. The transmitt light on the RDX does change to yellow when I key up, but doesn't open up, and shows someones is talking. I had used a scanner to search for the frequency and when I found it thought all was well, but when I programmed it into mine radio and went to key, "nothing", no-go. If you run across that info send a link or something. But I thank you.
cartman
Conover, nc
I thank you for the suggestion. Are you by chance referring to a frequency counter with a PL DPL search feature or an actual Police/fire/EMS scanner. I've got a couple scanners but they aren't that suphisticated, if not I'll have to search around, I know a fellow who has a frequency counter, or I try "ebay"?. Anyway, thanks
Need a scanner
You need a police scanner that can scan for the pl or dpl. I doubt a freq counter would work, it's gonna show the TX freq, not the PL freq, unless it had some sort of range setting. I've never heard of someone trying to read the PL with a freq counter, not saying it can't be done, just never heard of it.
Sounds like trial and error time for you. It shouldn't take you more than 10 minutes or so to keep one of the radios on the same PL, and run through 'em all with the other, until you hear something. Another thought would be run CSQ. I would imagine both radios can be set to that.
Astro25
Chicagoland
Or if you have a half hour to kill on the subject, you can start programming the radio that you CAN program, trying a different PL each time (working your way up from 67.0hz.... )
cartman
Conover, nc
Yeh trying all the CTCSS codes listed in my radio's owners manual crossed my mind, time consuming as you mentioned, but it is an idea. Someone on here sent me some PL codes for several Murz channels so I'm gonna give them a shot. Thanks for the help and still entertaining more idea's. The scanner idea sounds like it would work if I had one that would perform that function. Anyway thanks.
cartman
Conover, nc
I appreciate the suggestions. No, the frequency counter is a no-go. I checked with a dealer on ebay and those won't perform that function. I've gotten several suggestions on using a scanner with PL/DPL search capabilites, and I've seen other forum members on here with similar issues have had that suggested to them. I've got 3 unidens, but not sure if they'll do that. If you don't mind me asking, how would you use a scanner to search PL/DPL.
clanusb
Northern CA
first of all what scanners do you have?
make sure its a listed feature that they have. if they have it enable it, and tune it to the freq your using. when you key up a radio the scanner should flash the PL/DPL on the screen.
cartman
Conover, nc
As for my scanners, I've got all unidens, BC340C, the BC350C the uniden 92XLT handheld and BCT-8. From what I've looked into I think Uniden has 2, and Radio shack has a couple older models that will do PL/DPL search.
