Motorola RICK cable
K2NEC
NA
I have a an HLN3333 RICK that I don't have the cables for. I found the pinout for it in a manual but I'm wondering if I really need to use all 16 pins or if I can get away with only using the necessary pins between the RICK and CDM? If that's the case, which ones are really necessary?
I'm trying to cut a corner but maybe just doing all 16 pins is the best thing to do, I'm gonna be using the connector anyway, might as well make the most of it
K2NEC
NA
Ok so things like speaker out and the pins that are selected in CPS?
a417
Yes.
The accessory plug connections can be reasonably modified within CPS. IIRC, pins 3-6, 8,9,11,12 and 14 are either fully or partially programmable, or are limited to either in or out only. A few of them (pin 3?) can only be active low, and some of them are analog only (9 if my failing memory is correct). You can poke around in the CPS and see which are which.
[edit] fixing the most egregious grammatical atrocities.
K2NEC
NA
Ok perfect, sounds like I can make do with a Cat5 cable instead of having to get a 16 wire cable
n0esc
SE MN EN33
Worst case if you wanted to cover all your bases would be to use 2 Cat5 lengths and heat shrink or zip tie them together. Wouldn't be the first time I saw a multipin cable made in that or a similar way.
tropiradio
You just need the 4 basic connections to the radios, Tx audio, Rx audio, COR, and PTT. Very easily build if you have two of those 20-pin rear accessory plugs that came with the GM300 or M120 radios. Those plugs can easily be found on ebay as a kit with virgin pins included.
tropiradio
I forgot to mention one +12V to power the RICK, and the respective grounds to each radio, but guess you already knew that.
K2NEC
NA
Yea I figured as much since the RICK needs power, nevertheless 6 wires is better than 16
tropiradio
More like 32 wires, 16/radio.
I am guessing those original connecting wires must have been easier/cheaper to manufacture that way because there is simply no way to justify all of them.
