Motorola Saber with 1-pin?
BobbyWong
Toronto
Hi guys,
I was wondering if there was an adapter out there that would allow me to plug in PTTs or handmics that have Motorola 1-pin connections into a Motorola Saber IE. If this is not possible, I have a few PTTs that are wired for the Saber that I don't use anymore, and was thinking that I might be able to re-wire the 1-pin devices so that they could use the old Saber connections. However, I don't know if this is possible. If you guys have any thoughts, I'd appreciate it!
Cheers
b7spectra
EMS Dispatcher
Cobb County, GA
I don't believe there is anything like that on the market, mainly because the Saber is no longer supported (analog saber that is).
BobbyWong
Toronto
That is a shame.
I guess I have to make one then eh? I have never taken apart one of the Saber connectors before. There are 5 pins on the back. I can only imagine 2 are for the mic, 2 are for the audio, and one is power? Not too sure.
mancow
N.E. Kansas
Batlabs has the 12 pin options connector pinout. You need to suooly one of th pins with 1.5 volts to enable external accessories.
