Motorola scanner???
Ffbryce1
Michigan/Ohio
Would it be a good idea to buy a motorola radio and try to connect it to our local 800 trunked radio system? Is it possible to get rid of the transmit feature and just get it to scan? This way it would pick up every transmission and would not miss the first few seconds and be super clear? I need some ideas here. This 436HP is not doing the best with our 159.0900 frequency. It has a RS800 a tenna because I scan 800 frequency but it is having trouble picking up the 159.
iMONITOR
It's my understanding that most Motorola radios can be programed for receive only. However, working with a digital trunked system is problem. Apparently they need to be authenticated with the system, similar to a computer on a network, in order to function properly.
The stock antenna that comes with the BCD436HP is probably one of the worst you could use for 159.0900MHz. Have you tried another antenna, maybe one designed for 2m Ham band?
I would recommend something like the Diamond RH77CA (BNC mount), or the SRH77CA (SMA mount).
Diamond Antennas
http://www.universal-radio.com/catalog/hamantht/2368.html
parma,ohio
159.090
maybe get a VHF Mobile have 159.090 programed in it i have a NEW 2 channel Maxtrac in the box for sale this would be better than playing with a trunking radio.
ofd8001
Louisville, KY
joeuser
The Wretched
North Central Kansas
That RS800 antenna is specific to the 800-900 range. You Might want to get the 15$ telescoping with center load. Comet makes good antennas also.
Diamond Antennas
Diamond RH77CA SRH77CA Antenna
Using Motorola radios as a passive scanner opens a whole can of worms. It can be done but is NOT RECOMMENDED as the problems it could potentially cause may interfere with the system. If it's for trunking one method needs a system key and in some areas (including Minnesota) it's considered a crime to be in possession of it without authorization. They consider it as a computer hacking crime of something. Bottom line is to use a scanner and try to optimize the signal coming into it. As phase 2 hits, the older Moto's will be useless and getting a phase 2 radio is not cheap so a phase 2 scanner will be the only option. The good news is hopefully the scanner makers will make better scanners in the future (we hope). Yeah an APX series would be sweet, but taking out a second mortgage to pay for it ain't happening.
mikewazowski
Staff member
Central Ontario
Well said, jwilson. It's refreshing to see someone explain the pitfalls of why programming a Motorola radio for a trunking system is risky business without resorting to lies and half truths.
parma,ohio
i sent him a PM i have a 2 channel VHF Maxtrac he could use and stay away from trunking radios this is a NEW old stock never used i think would work for him?
burner50
The Third Variable
NC Iowa
I would say that if you're asking the question here, you should probably just stick to a scanner...
Not meant to be insulting, but the intricacies of doing this may be above your experience level.
Ffbryce1
Michigan/Ohio
I do understand. See I do have some connections and a Fire Chief I know has 1 trillion radios mostly motorola and scans everything within 50 miles of us. I do not see him often and when I do he is busy or we are talking business. He has already said he can program anything I want or help you do it. He is the one who suggested I get this 436HP. I am just not sure if he has everything he is talking about and if he is allowed to even do this.
N8IAA
Fortunately, GA
Use an antenna meant for VHF and for the 800MHz systems you scan.
But, if you think that a motherola radio suits your needs and you can afford it, what the heck. Go and get one. You've already spent $500 on a scanner that will work quite well when used with the proper antenna.
Larry
fireguyastro
delco,pa
Question , Are you going to use it for just analog conventional receiving? if so then yes you can use a Motorola radio , if your attempting to monitor a trunked system, then you are entering another realm of legality issues, you cant possess a system key without the sole permission of the system owner, if you get a trunked system hacked in to a radio if you get caught with it the fines and the consequences could be very severe.
Ffbryce1
Michigan/Ohio
I see thank you, I will not be getting a motorola. The thing is it works great now on every channel except that one, its just the first second is always cut out.
DickH
If you're near a large city, there may be a used two-way radio or used electronics store where you can buy a used Motorola or Johnson or GE radio that can operate on 159.09. If you use it at home you will need a 12 volt power supply, too.
joeuser
The Wretched
A free with all the above. You got a great unit, the 436 is very capable for your needs - you just crippled the VHF with the special 800 whip. For 15$ & a quick run to a Radio Shark - the telescoping center load antenna is really nice. There are discussions on these forums about the sections & best reception depending on which sections are collapsed. Good luck & enjoy.
Ffbryce1
Michigan/Ohio
Thank you everybody this question has been solved. And to reply on the telescoping we are not ready to sink another dime into this.
