Motorola SL3500e antenna connector
swwifty
Does anyone know the antenna connection type on the SL3500e? It's tiny, and I'd like to find maybe an adapter to add a bigger antenna if I could.
I can't seem to find anything on the internet anywhere on this, so maybe its not possible. I just wanted to ask first. Ideally a BNC connector would be great for a bigger antenna attachment on the top of these radios.
Thanks.
MTS2000des
5B2_BEE00 Czar
There is no ground, so you can forget about using anything to "adapt" to. It's a stud which is center conductor only. These radios aren't intended or designed for "ham" style giant antennas.
swwifty
I understand that, but still would be nice to add a bigger antenna if needed.
EWC_BDN
isn't the range fine how it is? the fix for it is to improve the system coverage not the radio antenna. The big sell on that radio is that it's small. That's the only thing it has going for it. Motorola sells radios with bigger antennas if you want a bigger antenna.
Though most people don't want a bigger antenna they want more range.
