Motorola SL7550 CPS issue/question
w5rah
I recently purchased a Motorola SL7550 and went to read the radio with the CPS and got the following message:
Error# 1027
Codeplug Version not supported.
I am using CPS 15.0 (Build 754)
The radio indicates
CP Version: 13.00.08
Firmware Ver: R02.08.05.0004
I also attempted to do a recover and an update through the CPS, but still get the same message. Would I need to upgrade to CPS 16 or should 15.0 be adequate? Thanks!
w5rah
Good deal. I’ll look into that. Fortunately 15.0 has served well for everything I have encountered but looks like stepping up to a newer version may be needed. I understand that downgrading firmware to a version that will work with 15.0 is possible but may not be a very easy task.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
I can't remember which version pairs with CPS v16, build 828, but that where you should be shooting for. Both firmware and CPS
Firebuff880
Boynton Beach, FL
CPS 16 Build 828 is for the R02.09.nn releases and is the last CPS build before the R02.10 move to CPS 2.0 and the new RM that establishes the base for Software Update Management (SUM).
