Motorola SL7590(e)
KD5WEK
Good afternoon folks, I'm looking to upgrade my older 900mhz radio and was considering the SL7590. I know many commercial radios do not out of the box work on the 33cm ham bands, can this one be moved to work in the 33cm range with the use of software as previous models can? It would appear that it transmits on 896-941 MHz, splits are 896-902 MHz and 935-941 MHz. I do see it I little higher than the needed 927 for repeater work. Ant thoughts would be appreciated.
KD5WEK
The SL7000 series are digital (TRBO) only and won't do analog. So while it may be possible to modify the CPS to allow OOB programming, you're looking at a DMR only radio if your desire is to replace older legacy analog stuff like GTX, MTS/MTX, etc.
Awesome, this is what I was wanting to know, thank you!
K2NEC
I'm not sure what you are replacing or how much you are wanting to spend but if $300 isn't above your budget then I would go for an XPR7580(e). 806-941, accessories and software area relatively cheap and easy to come by and they are great radios that will last you a long time. As long as the firmware isn't R2.10 it can be modified to do out of band as well if you need to.
KD5WEK
I had also looked at one of these as well, would be upgrading from an MTX9250.
alcahuete
Antelope Acres, California
Have you personally used a 7580e for ham radio? I have a standard 7580, and have always been told that the e model, unlike the other e models, cannot be modified to cover the ham bands.
N4KVE
PALM BEACH, FLORIDA
Correct. The E is hard coded to only work in the commercial band. The 7580, or the 6580 will work great in the 902/927 ham band. 6580’s are under $100 these days. Grabbed a few at the Orlando ham fest for $50 each. But DMR 900 ham repeaters are very rare, so unless there’s one near you, I’d stick with the 9250, as it works very well at 902/927.
alcahuete
That's what I thought. That's why I'm not sure why K2NEC said XPR7580(e). I have a standard one and it works great.
K2NEC
Oh...Interesting. I guess you learn something new every day. I figured since the out of band hack was more of convincing the radio to go out of band that it should work. I didn't know that the 7580e's were hard coded. Thanks for the correction guys
alcahuete
Yeah, I had heard that a few other places. I was actually thinking about upgrading mine to the e, since there is a noticeable difference in reception, and then I heard that. All the other e models can be taken out of band (VHF/UHF) with no problem at all. It's just the 800/900 one that can't, apparently.
