tropiradio
- Joined
- Mar 10, 2021
- Messages
- 182
Hello,
I do have an SLR5000 series repeater operating in analog only mode and that normally operates on AC power, but it also has a deep-cycle marine backup battery in case the mains power fails and a separate Victron smart charger. It works fine, but problem is one never knows when the repeater has fallen back onto battery operation so as to perhaps take some measures in order to minimize usage to extend the battery operation to the maximum, or at the very least to be aware of that battery operation has come into effect and not letting it run down the battery completely is also a good idea to avoid shortening the service life of the battery. That of course is another separate matter, but right now creating some sort of over-the-air alert is my main priority.
Not aware of any programmable pin on the rear DB25 connector that would change state once the repeater is operating on battery, or if AC has failed. On this last option, and it would certainly not be my most favorite one, is to get a wire to the internal power supply DC output so as to detect when it no longer is online. Another (external sensing) option that comes to mind is just sensing the AC mains with a 120V coil relay on the same outlet that feeds the repeater. That would certainly avoid having to pull the cover off the repeater and sounds like the easiest AC-present sensing solution.
But once I do have a signal that changes states when the power mains have failed and the repeater is operating on battery power, how could one insert (ideally) a short beep tone that only would be transmitted on the tail, or when the person currently talking releases its PTT (repeater "COR" changes state).
If this where for a more conventional older style repeater where one could easily get into the repeat audio path it would be quite easy. But on the SLR the only way to get into that audio path is to disable internal audio routing, as for example when an external controller would be used. But hoping to keep it simple so would not have to reconstruct the whole audio path aside from injecting the short beep. Not aware of any other ways to broadcast an alert in any other form, not necessarily audible. Also it does not help not having the detailed service manual of the repeater, not even sure it is available, or someone has posted it somewhere out there in PDF.
I am also aware of RDAC, and that it would allow to check on the whole status of the repeater, but I am trying to avoid having to go that route as it would be a bit of overkill.
I'm open to ideas, anything that might accomplish one knowing that the repeater is on battery while keying it up would be fine. Thanks in advance for any suggestions.
