Motorola Solutions LEX L11 update to Android 11?
kd7wer
I am wondering if anyone knows what the update process is for the Motorola Solutions LEX L11 smartphone? Can it be updated by the user like other Android devices or does it need to be sent to Motorola? I purchased a second-hand device which is running Android 9 and wish to upgrade it to Android 11.
If this needs to be moved to a different forum please move it. This device seems to be an oddball in the smartphone space because of its PTT features with APX connectivity and control. I tried to find the best forum, but I know that doesn't mean I did.
jeepsandradios
East of the Mississippi
If there is a approved version it should update via your provider just like other phones. I dont know the approved verison on the 11 and mine is in my truck right now.
FKimble
Newnan, GA
I think you did!
Frank
daine1619
Washington, Pennsylvania
I’m also interested in it. Wanted to try and see if I liked the L11 before getting a cell plan for it.
When you go into software update it gives me “your software is up to date” and it’s running on android 7 I believe
kd7wer
The Motorola documentation for it indicates it should run Android 11. But when I go to check for updates it says that it is up to date and the last installed security update is from like May of 2021. My settings indicate the phone is on Android 9. I need to run an app for work that requires Android 11, hence the question. I am running on Verizon, but when I put in my Mint mobile SIM I got the same result when checking for updates. I'm not too familiar with the normal Android update process.
@FKimble Thanks! I was hoping that wouldn't be misunderstood. I was speaking of all the different forums here on RR.
ME801
NV
Have you tried a hard restart? Power off, take the battery out, hold the power button down for 10 seconds, reinstall the battery, power on the phone. That's how I ended up with Android 11, I got a corrupted update (even though it said "Update Successful"). It required a trip to Depot to get a working update.
kd7wer
@ME801 I will try those steps. How did you know you got a corrupted update? What did the trip to Depot cost?
ME801
NV
After the update it would not connect to cell towers or wifi networks. It would show connected, but could to make/receive calls or data. The cost thru a dealer was $25 to diagnose, then a total of $500 (they said it needed a new frame also).
jeepsandradios
I just grabbed mine from the truck and checked the software and I'm running Android 11. Its on First Net and Verizon but not sure which did the update. Think it was on Verizon Sim when it got the update.
aglowgibbon
Canton, Texas
I wonder if I could get a prepaid Verizon sim to do it; something as cheap as possible. I would like to avoid sending it off to depot.
ME801
NV
How much did that cost? I’d hate to depot a device I paid <$200 for..
I don't remember since it needed a front screen also.
As JeepsandRadio's said a prepaid Ver SIM may do it. My LEX had a FirstNet SIM when I got the corrupted update.
WRTF671
I'm in the same boat, I would make my Lex my primary phone if I could get it onto a newer OS.
waynedc
Vail, Arizona
With a Motorola MyView account, you can download - "LEX L11 R40.34.10 Firmware Update File" - which was released on 12/24/2023. There are instructions online for upgrading your LEX L11n yourself, I believe via the SD card. This should give you Android 11 and bring all of the Motorola LEX specific apps and system options current.
Firebuff880
Boynton Beach, FL
But why do that Android 14 is on my Pixel and most Android-based devices are at 13 or 14 these days.
