Motorola Spectra setup ?
emtbls1987
Kalispell, Montana
Hello
I have a Motorola Spectra Model T83...., anyways i have a converter box that i use for my Emperior CB Radio that allows me to use it as a Base Station. anyways i have everything setup except three wires on the end of the Control Cable. One is Orange, the Second is Green, then the other two are black. i imagine these are for the speaker. anyways i believe that the Orange is the ignition cable. is their anyway around using this like say for a base station. and then the green cable. i dont know what is is for. please help
emtbls1987
zz0468
Everything you ever wanted to know about the Spectra (and a few things you don't) can be located at batlabs.com - including what the green wire is for.
emtbls1987
Kalispell, Montana
setup ?
Thank You
Thank all of you for the info. i will besure to not short out the speaker. and the Radio as well. I know specially the radio if you short it out might as well throw it away depending. anyways thank you all
mancow
N.E. Kansas
The radio really isn't that big a deal. It will blow a fuse first. The audio amp is what you have to be careful with.
emtbls1987
Kalispell, Montana
got another Question.
can i just take two fuses, and run the Orange Ignition Wire to the Power supply, and do the same with the Green so that i dont have to run it to the Fuse box. ?
mancow
N.E. Kansas
Yes, if you want it to act as a basic radio that is not ignition switched then just run the orange and green lines to the same power source as the main power leads. The power will then be controlled entirely by the radio's power switch.
