BUCKSHOT_106
I recently required this radio in a trade. It powers up rx/tx perfect. But I was looking to sell on Ebay and you can barely give these things away. Lucky I don't have much in it. Are these radios fissing on completely?
It's unfortunate that most people are misinformed about the Spectra. It will make the 12.5 kc transformation with little or no cost. The radio can have it's TX deviation lowered, and if you use the RX board from a 900mhz you just narrow banded the radio. You can make a Spectra a compliant 12.5 radio, at even less cost. Merely change the reference oscillator with a still very much available 00002 or 00001 standard, as I intend to do to over 150 VHF's I am responsible for. BTW the radios had an option for that very oscillator, so it makes the radio type accepted. As far as the cap issue, I believe there is enough information out there to fix that issue. The costs involved are minimal considering the radio you get when finished. Hands down a better radio that the CDM line.
There is no way to field program a spectra..
pretty bulletproof.
Would make an excellent choice for aprs/packet.
They do not work very well down in the 144.XXX spectrum without a bit of vco tweaking,
at least on the tx side. Not sure about rx.
Never seen that to be an issue, with either bandsplit. IIRC the bandsplits were something like 136-162 and 146-174.. I never had a problem taking any of them (hi or low power,regardless of split) from ~143-170 without any tweaking.
I concur, never had a problem entering and using VHF FM amateur freqs in either bandsplit unless the radio had a problem to begin with. I've seen some that were deaf as a post on the low end, but a thorough and complete alignment by the book by someone who knows what they're doing always took care of it unless there were other problems.
Well then, let me be more specific. I do not half-ass radios, and I do check each and every radio that goes through my hands, and have done so for the 40 or so years I've been involved in the two-way radio business. Sometimes there are significant differences between radios, and sometimes the low split radios are worse at 144-148 than the high split radios are, but so far I have never encountered one that had any problem after a proper alignment. I stand by what I said, and since I should not have left the "and use" portion of my post open to question, I defer to your "correction."
